Hardware Replacement FAQs Follow
What is Tempest's warranty policy?
The full policy information can be found here, but these are the basics:
- Two (2) Year Warranty - If the Device is or becomes inoperative as a result of a manufacturing defect within two (2) years from the date of purchase, we will replace it with a comparable replacement product at no cost. This includes Device failure due to defect but does not include failure due to misuse in unintended ways, abuse such as dropping the Device, natural causes including lightning strike, or unnatural causes such as vandalism.
- Ten (10) Year Legacy Discount - If a Device is or becomes inoperative as a result of a manufacturing defect outside of the Two Year Warranty period but less than ten (10) years from the date of purchase, WeatherFlow offers a 50% discount off manufacturer suggested retail price (MSRP) on a replacement Device.
How do I submit a warranty claim?
First, know that many issues that seem like hardware failures can be fixed with a little troubleshooting. Check out our troubleshooting guide and/or contact support for more help.
Use this form to open a ticket. We'll need to know either the station ID or email address used to register the station. Alternatively, you can share the serial number of either your Tempest or Hub, or send a photo of the QR code on the device's sticker. We'll also need a proof of purchase, if the Tempest System wasn't originally ordered from our online store.
My replacement is here; how do I connect it?
I'm replacing a Tempest device only (keeping the same Hub)
Use the app to connect your new device to your station Hub. There is a 'Replace Device' button in the app which will swap the new device in the old device's place. This will preserve the device data history. Please follow these instructions carefully...
- Turn on the new device. The LED should eventually slowly blink green, indicating it is in pairing mode. If the LED does not stay blinking green, press and hold the LED button until it flashes to reset the device.
- Open the app, go to Settings > Stations > (choose your station) > Manage Devices > (select the device you are replacing) > Advanced > Replace Device.
- The new device will appear on screen, choose the new device to finish connecting it.
- The LED on the base of the Tempest should flash green and then go out, indicating it has successfully paired to the Hub. Then you can check the app for current observation data.
Note: The new device will retain the old device's name (which may be defaulted to the old serial number). You can rename the new device: go to settings > stations > choose your station > manage devices > choose the Tempest device > tap the name to edit.
I'm replacing a Hub only (keeping the same Tempest)
- Physically retrieve the Tempest device and unplug the old Hub.
- Delete the old station: Open the app, go to Settings > Stations > slide the old station left, then confirm delete.
- Reset the Tempest device so it can pair with the new Hub.
Press & hold the LED button on the base of the Tempest next to the power switch until it flashes. The LED will then slowly blink green indicating the device is ready to pair to a new Hub. - Create a new station: In the app, set up a new station using the new Hub (Settings > Stations > tap the + icon in the upper right).
- Reinstall the device: You can install the device outdoors once you confirm data is reporting in the app.
- Contact support as soon as you've completed setup and configuration so we can recover your old station data and stitch it to the new station.
I'm replacing the whole station (new Tempest + new Hub)
- Delete the old station: Open the app, go to Settings > Stations > slide the old station name left, then confirm delete.
- Create a new station: In the app, set up a new station using the new Hub (Settings > Stations > tap the + icon in the upper right). Follow the in-app prompts to connect the hardware to your account.
- Reinstall the device: You can install the new device outdoors once you confirm data is reporting in the app.
- Contact support as soon as you've completed setup and configuration so we can recover your old station data and stitch it to the new station. Note, you MUST delete the old station first, if you want the old data attached to the new station ID.
What do I do with my old hardware?
If we sent you a prepaid return label
Please mail the equipment back after you receive the replacement. If you are returning a used Tempest device, please do us a favor before packaging the device for shipping...
- Turn off the device: flip the power switch on the base of the unit to the off position.
- Wipe clean any excess dirt, bird droppings, or insects from the device.
- Dispose the old pole/flat base mount.
We appreciate this!
If we did not ask for the hardware to be returned
In some cases, we may not ask for your original hardware to be returned. You are welcome to keep the equipment, or dispose of it responsibly. We also have a recycling option.
If you have legacy Smart Weather System (AIR/SKY) devices
Merging Data from Legacy Smart Weather Stations to a Tempest System:
Data cannot be merged from an AIR and SKY device to a Tempest device. If you want the historical AIR and SKY data on your station, you must attach the AIR and SKY to the new station Hub. Then, when the legacy devices are in place, we can recover the archived data to those devices. You don't need to continue operating the legacy devices, but they need to be added to the station Hub as placeholders for the historical data.
EU and AU/NZ Versions of the Legacy Smart Weather Stations:
Originally, we expected complete compatibility with the original AIR and SKY devices with the new Tempest Hub. To our surprise, we discovered that this would not be possible due to some radio communication issues. The old AIR and SKY devices will not be able to be added to the new Hubs. We actually knew this would be a limitation with Australian versions of the devices due to recent changes of RF standardization but the incompatibility was unanticipated for European versions.
The only consequence of this is that owners of the original Smart Weather Station will need to keep the AIR and SKY operating on the old Hub. You can still operate multiple stations (Hub + devices) on your account; two Hubs, two stations with AIR + SKY on the old Hub and Tempest on the new Hub.
Anything else I need to know?
Integrations
If you replaced the Tempest device only, your station ID and device ID will remain the same; so any integrations that use that will be unaffected.
If you replaced the Hub, or both Tempest and Hub, you'll have a new station ID.
For WU: You can easily use the same WU PWS station ID and Key - first unlink the old station on your account on the web: https://tempestwx.com
When the new station is set up and reporting, re-do the WU data feed on the website and use the same ID and key to link them. You'll need to grab the WU PWS ID and key from your account on WU under your weather station profile.
Calibration settings
Device calibrations are hardware-specific, so they will not need to be carried over. Your new device will be updated with new calibrations using our automated Continuous Learning software.
