Data Export Follow
You can export stored readings directly from the Wind & Weather meter app and share them in various ways, including a CSV file with all measured & calculated values, including latitude and longitude coordinates of where the reading was taken if location permissions are enabled for the application.
- Take a reading using either the WINDmeter or WEATHERmeter device and save it.
- Tap the main menu in the top left > select "History", then select "Edit"
- Choose one or more reports you wish to export.
- Then select "Send" and finish exporting the saved readings.
