Technical Specifications Follow
WeatherFlow WINDmeter
The WINDmeter is designed to be the most accurate handheld anemometer on the market at its price point. Calibrated at the University of Florida’s Aerospace Engineering Department, the operating range extends from the smallest puff to well over hurricane force winds. Even if you don’t hold it directly into the wind, the unique design will measure very accurate wind speed information.
- wind speed (avg, gust, apparent, true)
- wind direction (magnetic, true)
- crosswind, headwind, tailwind
- plugs into 3.5mm audio jack
TECHNICAL SPECIFICATIONS
Operating temperature range: -40 C to 46 C
Power: 12 mW
Weight of unit: 16.7 g
