Troubleshooting Guide (Setup, WiFi, Hub & Tempest Device) Follow
- Hub not found
- WiFi network not found
- 211 Error Code
- Tempest device not found
- Station setup but no historical data
- View all error codes
- WiFi network is not found
- Hub cannot connect to WiFi
- 211 Error Code
- Hub loses WiFi connection - "Station offline"
- Ethernet connection
- Data is not current / device is not connected
- Tempest device has lost power
- Tempest device has disconnected from the Hub
- Sensor not reporting data
- Replacing a disconnected device / swapping a new device
First Time Setup Troubleshooting
Hub not found
If you are getting a "Hub not found" error message, this usually means the app is not detecting a Bluetooth connection between the Hub and your smartphone or tablet. Try the following steps...
- Close the app completely, close the app from running in the background.
- Unplug the Hub for 10 seconds and plug it back in to power cycle the device. Wait a minute for it to reboot.
- Toggle your phone's Bluetooth off and back on.
- Reopen the app and proceed with initial setup.
Additional Hub Bluetooth connection tips
- For Android devices: Enable Location Services. Enabling location services is necessary to scan for Bluetooth LE devices.
For iOS devices: Make sure the app is allowed Bluetooth permission. Go to Settings > scroll down and find the Tempest Weather app and enable "Bluetooth Sharing" for the app.
Do not try to manually pair the Hub to your device through Bluetooth settings. If you manually paired to the Hub, disable the pairing in your phone's Bluetooth settings. Then power cycle the Hub. Close and reopen the Tempest Weather app.
- Make sure the app has permission to use Bluetooth on your device.
- Restart your smart phone or tablet.
- Toggle Bluetooth off on your device and then back on.
- You should only have the app open on one device during initial setup.
- Disable Bluetooth on other nearby devices. It's unlikely, but possible the Hub has connected to another BLE device nearby, laptops, computers, smart watches, etc.
If you don't see your WiFi network in the list of available networks...
- Move the Hub closer to the WiFi access point
- Refresh the WiFi network list in the app
- Close and reopen the app
- Reboot your WiFi access points
- Turn off the Tempest sensor device
Additional WiFi network tips
- If you are using multiple access points, choose the master access point when setting up the Hub's WiFi connection. Locate the Hub closest to the master access point.
- Make sure your router is broadcasting a 2.4GHz network. The Hub will only find and connect with 2.4GHz networks. If you have a mesh network with 'band steering' capabilities, you will need to establish a static 2.4GHz network for the Hub to stay connected to.
211 Error Code
If you're getting this error code when attempting a WiFi connection, it could be a result of a bug with a WiFi router setting called Fast Roaming (802.11r). You can get around this by disabling fast roaming and then re-trying the WiFi connection in the Tempest Weather app. Some routers may not have this setting so you can search your router model online and check first.
To disable Fast Roaming (802.11r) in your router settings:
- You may have an app to manage your home WiFi or you can log in to your network directly from any web browser. There are login instructions printed on the back of your router. Open a web browser on your phone or computer and enter the address listed on the back of your router (for example it might read, 192.168.0.0). Login to your router using the login credentials printed on the back of your router, (IP address and password) unless you have changed them.
- Find the Fast Roaming (802.11r) setting for your 2.4GHz network and disable it. Different routers have different instructions so you can search online where to find this setting but it's usually easily visible or under advanced settings. Be sure to save the configuration changes.
You can also call your internet service provider for help if you need to.
After the setting is changed, power cycle the Hub and wait a minute for the Hub to fully reboot. Open the app and try to connect to your WiFi network again. Go to settings > stations > choose your station > WiFi Setup > Tap Next and scan for your network. If you don't see your network name, try manually connecting instead, and enter the name or SSID of your 2.4GHz WiFi network.
Your Hub should be queued up for a firmware update within a few days. After this update to version 319 or higher, you can reenable fast roaming on your router if you prefer.
The Tempest device must be in pairing mode before connecting to the Hub. Pairing mode is indicated by a slow blinking green LED on the base of the unit.
- Remove the mounting attachment.
- On the base of the device, press and hold the clear button next to the power switch until the LED flashes.
- After a few seconds the LED will slowly blink green, indicating it is ready to pair to a Hub. Continue with the setup procedure in the app.
Additional device connection tips
If the LED on the base of the unit is not illuminating at all, there could be a low battery issue. Make sure the device is turned on and place it outdoors with the solar panels facing towards the sun. The Tempest device can charge sufficiently within a few hours. Check the LED again.
If your station is setup but you're not getting any historical data, then your outside Tempest device is likely not properly paired to your station. To check that, open the app and go to settings > stations > select your station > tap manage devices > if no device is listed then you'll need to add your device:
- Remove the mounting attachment on the bottom of the device.
- With the device powered on, press and hold the clear button next to the power switch until the LED flashes.
- Then add it to your station by going to settings > stations > select your station > tap manage devices > add device > the device will appear on screen, choose the device to finish connecting it.
Bluetooth Connection Troubleshooting
Mobile app connection to Hub - "Hub not found"
Bluetooth connection to the Hub is only necessary if you are connecting the Hub to a WiFi network, connecting sensor devices.
If you are getting a "Hub not found" error message, this means the app is not detecting a Bluetooth connection between the Hub and your smartphone or tablet.
- Close the app, unplug the Hub for 10 seconds and plug it back in to power cycle the device. Wait a minute for it to reboot, then reopen the app and proceed with initial setup.
Enable Bluetooth and make sure the app has permission to use Bluetooth on your device.
Android device users must enable location services and nearby devices in the app permissions for Bluetooth connectivity.
For iOS devices: Go to Settings > scroll down and find the Tempest Weather app and enable "Bluetooth Sharing" for the app.
- Do not try to manually pair the Hub to your device through Bluetooth settings.
- Disable Bluetooth on other nearby devices which the Hub might be connecting to. (This could be determined if the Hub's LED is blue, or the BLE LED is illuminated green on the new WiFi Hub, but the app is completely closed on your device).
Hub WiFi Connection Troubleshooting
If you are having trouble locating your WiFi network, try the following suggestions...
- Tap 'Refresh' in the top right on the WiFi Setup screen in the Tempest app.
- Make sure your router is broadcasting a 2.4GHz network. The HUB only connects to 2.4GHz networks. If you have a mesh network with 'band steering' capabilities, you will need to establish a static 2.4GHz network for the Hub to stay connected to.
- Reboot your Hub and your network router and any range extenders.
Close and reopen the mobile app.
- Turn off the Tempest sensor device when setting up a WiFi connection. This could help free up the Hub if it's busy processing data.
- If your SSID is hidden, choose Manual Setup and enter the SSID.
- If you have a network with band steering capabilities, and it is currently broadcasting a 5GHz network only, the Hub will not detect it. You will need to establish a static 2.4GHz network for the Hub to connect to.
If you get a 'Hub not connected' error message in the app, see Bluetooth connection issues
- Check your password and try again.
- Make sure your router is broadcasting a 2.4GHz network. The Hub only connects to 2.4GHz networks. If you have a mesh network with 'band steering' capabilities, you will need to establish a static 2.4GHz network for the Hub to stay connected to.
- Restarting hardware fixes a lot of problems - reboot your Hub, your network router and any range extenders; unplug them for a moment and then plug them back in.
- Close the app completely, make sure to exit out of background and then reopen the app.
Additional WiFi Connection Tips
The Hub does not support WEP security protocol and some WPA3. Check your router settings and change the security on the router from WEP/WPA3 to WPA or WPA2. Some older routers may still be using a WEP security protocol which is outdated and not as secure.
The Hub does not support Enterprise networks, username authentication or captured portal connections.
Set up a guest network if your router is capable of doing so. Look to your router's user manual for specific instructions if needed. Some models may have admin login information on a sticker on the router itself.
Mesh networking can cause connection issues with the Hub. If you are using multiple access points, try temporarily shutting down all but one access point, locate the Hub closest to the 'master' access point and try the WiFi setup again.
If you have a network with band steering capabilities, you will need to establish a static 2.4GHz network for the Hub to stay connected to.
The Hub could be connected to a different device over Bluetooth. Check if the Hub has an active Bluetooth connection even when the app on your mobile device is completely closed.
If the single LED is blue on the Classic Hub, or if the BLE LED is illuminated on the new Standard Hub, that means either the app isn't completely closed yet, or the Hub is connected to a different Bluetooth device.
- Turn off Bluetooth on nearby devices and power cycle the Hub. Wait a minute for the Hub to reboot. The single LED on the Classic Hub should be red or the status LED on the Standard Hub should be red. Re-open the app and wait for the Bluetooth connection to be indicated on the Hub. Go to settings > stations > choose your station > WiFi Setup > Next > follow the steps in the app to connect to your WiFi network.
211 Error Code
Reboot your Hub, your WiFi router and all range extenders/access points.
Wait for the Hub to reconnect automatically, the LED will turn green or the WiFi LED will illuminate green on the new WiFi Hub. If the app is open on any device it will show a blue LED or the BLE LED will illuminate green on the new WiFi Hub.
To reconnect to WiFi manually, open the Tempest app > go to Settings > Stations > (select station) > WiFi Setup > follow the steps to reconnect the station Hub to your 2.4GHz WiFi network. -
Check the power supply.
- Make sure the cable and power supply are firmly connected.
- Try a different power supply if you have one available.
Check the Hub's signal strength in the app.
- Open the app, go to settings > stations > (select station) > tap the Status row and note the RSSI value for the Hub device which is an indicator of signal strength. A weaker signal would be between -80 to -100. If you have a weak signal, you may need to locate your Hub closer to the router or master access point.
- If you have a mesh network with band steering capabilities, this will cause the Hub to drop offline when the network switches to 5GHz. You will need to establish a static 2.4GHz network for the Hub to stay connected to.
Connect the Hub to the master access point.
This will offer a more stable connection than if you connect to a range extender. Unplug range extenders and refresh the available WiFi list in the app to avoid confusion on which network to connect to. - Check your firewall security settings. The Hub may connect to your network and show a green LED but strict firewall settings can prohibit the Hub from communicating with our cloud servers.
If you're still having trouble getting the Hub reconnected to your WiFi network, clear the saved WiFi configuration and reconnect to the WiFi network in the app.
- Reset the Hub: while the Hub is powered, press and hold the reset button on the back of the Hub with a toothpick or paperclip, and release the button when the LED flashes or the WiFi LED flashes on the new WiFi Hub.
- Reconnect to WiFi: Open the app > go to settings > stations > choose your station > WiFi Setup > tap Next > follow the steps in the app to connect to your WiFi network.
Ethernet Connection
- Make sure the ethernet cable is fully plugged in.
- The ethernet port is not POE, can use a USB-C/ethernet splitter.
- Ethernet won't bypass firewall settings in the network.
Cellular Connection Troubleshooting
Cellular network not found
- Make sure the cellular antenna is connected to the correct side, denoted by the purple coloring
- Check to make sure the Hub is plugged in and has power
Cellular data signal may be very weak
- Cellular Hub will not work everywhere
- If your phone's cellular strength is weak very likely the Hub's is too
The SIM card is certified for use in select countries
- You can't bring a North American cellular Hub to another country or vice versa.
Hub loses cellular connection - "Station offline"
Check the cell status field in the Tempest app: settings > stations > select your station > status > cell status.
A value closer to 0 is best:
Excellent: -10 < RSSI < 0
Good: -15 < RSSI ≤ -10
Fair: -20 < RSSI ≤ -15
No Signal: RSSI ≤ -20
Reboot the Hub.
- If the Hub is indoors, try moving it to a new location as well.
Re-do the cellular antenna connection.
- The antenna collar needs to be tight, but the antenna itself is able to spin freely.
Check the LED lights
- If cellular LED is not illuminated = not connected to cellular network
- If status LED is red or not illuminated = issue connecting to our servers
- If your Hub only has one LED - red = not connected to cellular network or our servers
If issues persist please contact us for further assistance.
Back to top
Hub LED Status Indicators
Tempest 26 WiFi Hub
Standard WiFi Hub
| App Closed (First Time Setup) | App Open | App Closed | |||||
Start ⚪ BLE ⚪ WIFI ⚪ STATUS
Hub Powered ⚪ BLE ⚪ WIFI 🔴 STATUS |
Start App ⮞ 🟢 BLE ⚪ WIFI 🔴 STATUS |
Pairing Device ⮞ 🟢 BLE ⚪ WIFI 🔴💥 STATUS |
Paired ⮞ 🟢 BLE ⚪ WIFI 🔴 STATUS |
Wi-Fi Up ⮞ 🟢 BLE 🟢 WIFI 🔴 STATUS |
Server Up ⮞ 🟢 BLE 🟢 WIFI 🟢 STATUS |
Done ⚪ BLE 🟢 WIFI 🟢 STATUS |
Classic WiFi Hub Green: Connected to WiFi network. Blue: Connected to mobile device Bluetooth (BLE). Occurs when the mobile app is open on a nearby device. BLE connected status supersedes WiFi connection status. Blue + Cyan Flashing: Hub is in pairing mode. RED: Hub is powered but not connected to WiFi or Bluetooth. RED flashing: Hub is rebooting and/or not getting enough power. |
Cellular Hub (single LED) Green: Connected to WiFi network. Blue: Connected to mobile device Bluetooth (BLE). Occurs when the mobile app is open on a nearby device. BLE connected status supersedes WiFi connection status. Blue + Cyan Flashing: Hub is in pairing mode. RED: Hub is powered but not connected to WiFi or Bluetooth. |
Cellular Hub (multiple LEDs) 1. Cellular Green: connected via cellular network. 2. Ethernet Green: connected via ethernet. 3. BLE Green: Connected to mobile device Bluetooth (BLE). 4. WiFi Green: Connected to WiFi network. 5. Status RGB
Tempest Device Connection Troubleshooting
For troubleshooting sensor measurements and accuracy, e.g. temperature, humidity, pressure, wind, rain, lightning data, see instead, Troubleshooting Measurements & Data.
The Tempest is not reporting current data or there is no data history
There are a few reasons why a Tempest device may not be reporting current observations...
1. The Tempest device has lost power
- Check the app to see if the device has power. The voltage reading in the app for the Tempest device should be above 2.35 volts. Make sure the solar panels are receiving direct sunlight in order to charge.
2. The Tempest device has disconnected from the station Hub
Power cycle the Tempest sensor device.
Remove the device from its mounting attachment. On the base of the device, switch the power OFF for a moment and then back ON. You should see a quickly flashing green LED if the device reconnects to the Hub successfully. -
Move the Hub to get a better signal to the Tempest sensor device.
Check the RSSI value, which is an indicator of signal strength. Go to settings > stations > (select station) > tap the Status menu > scroll down to the connected device. A weak signal would be between -85 to -100. If the signal is weak, consider moving the Hub closer to the device which may be easier than relocating the sensor device. A direct vertical alignment is not the best positioning for a good radio connection, i.e. if the Tempest is mounted directly above the Hub on the roof. -
Reset the Hub's radio.
1. Unplug the Hub.
2. Using a thin tool, push & hold the reset button on the back of the Hub.
3. Keep the button pressed and plug the hub back in.
4. Wait for the blue LED on the back of the Hub and then release the button.
3. Failed sensor(s) or sensors not reporting, "--" seen in device observations
Check the sensor status. Go to settings > stations > choose your station > scroll down and tap the status menu > scroll to the connected device > note the sensor status message towards the bottom.
If you see any failed sensor status in the app, power cycle the device.
- Remove the Tempest device from its mounting attachment.
- On the base of the device, switch the power OFF for a moment and then back ON.
- Wait for the LED status light. To check the LED status, press the button once for an indicator light. See LED status indicator references below.
Tempest device LED status indicators
The Tempest device's LED will not stay illuminated, even when it has power. To activate the LED status indicator, press the LED button on the base of the unit next to the power switch.
Red LED: The device may have a non-responsive sensor. This status supersedes all other device statuses.
If you're seeing a failed sensor status in the app or a red LED on the device itself, please check the Tempest device troubleshooting steps above. If you cannot resolve the issue, please contact us for assistance. Do not delete the device from your station.
Purple LED: The device has not successfully paired to a Hub.
If you see a purple LED, the device needs to be reset the device reconnected to the station Hub.
- Remove the mounting attachment from the Tempest device.
- On the base of the device, press and hold the translucent button next to the power switch until the LED flashes.
Open the app, go to settings > stations > (select your station) > manage devices > tap “+” to add the device to the station Hub > select the serial number on screen to finish connecting the device.
Note: If you are instead replacing a device on your station - after resetting the unit go to Settings > Stations > (choose your station) > Manage Devices > (select the device you are replacing) > Advanced > Replace Device > follow the remaining steps in the app to connect the new device.
Slow blinking green LED: The device is in pairing mode.
If you have not connected the Tempest device to your station Hub yet, then you will want to add it as a new device:
- Open the app, go to settings > stations > (select your station) > manage devices > tap “+” to add the device to the station Hub > select the serial number on screen to finish connecting the device.
If the Tempest device is already on your station but you have a slow green blink from the LED, then you will need to re-pair it to the Hub:
- Open the app, go to settings > stations > (select your station) > manage devices > select your Tempest device > advanced > in red tap 'replace device'.
- The app will likely not find the device during the searching process, that's ok. The Tempest should have automatically reconnected to your station Hub during that process (LED light on the base of Tempest will go out). Once it's done searching you can navigate back to the main Weather page using the cancel button.
Green LED: The device is paired to a Hub.
The Tempest device should be connected and reporting data to the station Hub. If you have a green status and you are not seeing any minute by minute observations you may need to check your phones internet connection and/or the Bluetooth connection to the Hub. Please contact us for assistance if you cannot resolve the issue.
