Tempest Installation Gallery Follow
Welcome to the Tempest Gallery!
The photos shown here are actual Tempest installations from real customers. We hope you enjoy and get some good ideas for installations.
Jump to...
Flat Base Attachment Installations
Pole Mount Attachment Installations
Roof Installations
Fence/Post mounts using flat base attachment
Nearby trees can impede wind flow, leading to lighter than expected winds.
Other mounts using flat base attachment
Fence/Post using pole mount attachment
Roof Installations
Tripod mounts
Mounting too close to a metal roof can skew temperature and humidity data, getting it higher up as seen above is good.
Eaves/Fascia mounts using pole mount attachment
With 1-2 ft roof clearing winds can be impacted due to turbulence.
Non-penetrating roof mounts
Chimney mounts
If exhaust is active temperature and humidity readings could be skewed.
Pole to pole mounts
Misc. roof mounts using pole mount attachment
Nearby trees can impede wind flow, leading to lighter than expected winds. If pole is connected to an active exhaust then temperature and humidity measurements can be skewed.
