Bird Deterrent Accessory Follow
The bird deterrent accessory easily attaches to the head of a Tempest or SKY device. It is meant to deter birds from perching on top of the device to mitigate false rain readings. This is an optional accessory that most Tempest owners will not find necessary. It is only recommended to use if the installation is frequented by perching birds that are causing problems fouling up the top of the device or triggering false rain readings that aren't filtered out by software. The bird deterrent accessory is available for purchase in Tempest shop.
Installation
Fit the band around the head of the device. It is important to keep the band...
- below the vibration isolator (slot)
- above the wind sampling area (gap)
