Forecast Tables Follow
The Forecast Table displays hourly forecasts from computer models. There are Basic and Detailed views which include less or more variables such as precipitation, cloud cover, pressure, etc. Some variables, like wave height & period, are only available using certain computer models that calculate those parameters. For more info on forecast models, see weather forecast model options.
See instructions using the mobile app or website.
Jump to: Forecast Table Key
Finding Forecast Tables through the Mobile App
From the main menu, select the Wind Map. Tap on a station or spot to open the preview panel. Tap Current Conditions & Forecast and view the Complete Report.
- Click on the Forecast option, or scroll down to the container.
- The Tempest Real-time Refresh Model (TRRM) will be selected by default. Other forecast models are available as long as membership level permits access.
- Toggle Basic/Detailed mode for less or more forecast variables.
- Toggle Daily/7 Day for different timeframes.
Finding Forecast Tables through the Website
From the Wind Map, click on a spot to open the preview panel, then click Forecast.
- To view other model options, make a selection from the model drop-down menu.
- Toggle Daily/7 Day for hourly or summarized forecast tables.
- Slide the table or scroll the preview window at the bottom to jump to a certain time period.
Forecast Table Key
The Forecast Table can be displayed in Basic or Detailed mode, as well as Daily or 7 Day view.
When viewing the Detailed version of the Forecast Table, the green dots in the Precipitation row indicate the amount of rainfall in the forecast. More dots equate to higher amounts expected.
